[SOLVED] RGB lighting control issues
Peterthecat1
113
Just upgraded my PC to a MSI MPG Z390M Gaming Edge AC and a i7 8700K with a cooler master ML240L RGB cooler and I have corsair keyboard/mouse/mouse pad that are also rgb..previously I was controlling only the perif's with the icue software now that I have the RGB fans/cooler, which are connected to the motherboard, I want to control all of my goodies w/ a single software and sync everything up but icue doesnt see the motherboard and msi mystic light will not open on my PC(says platform not supported) and I dont know if it will control the perif's anyway...how the hell can I get everything talking to each other to get m,y rgb's to sync up
Sadly when you purchase parts from different companies, it makes it difficult to have them all sync together since they use different programs for control. MSI does have potential to control Corsair peripheral's due to a small partnership between the two, but it's a very limited amount of products that can be shared. I'd recommend to look into fixing the Mystic Light installation, and then you can use your programs to assign similar static colors to each device for a uniform effect.
well a guess would that be that you could , first try to sync your cooler RGB in your motherboard settings (bios) or with its own switches , then try to sync those two with the rest of your system with the software you install on your windows 10 .
