RGB on gigabyte rx 580 8gb not working - Plz Help
Oct 4, 2018
6
So I recently built a computer and I got pretty much everything up and working. However, for some reason the Aorus software will not change the color of my graphics card and I was really hoping to make my pc have matching colors. Whenever I hit the LED light change button in the Aorus software, this new RGB fusion screen shows up. It also says at the bottem of it: Auros 20 series graphics card, even though I have an rx 580. Been trying every solution possible and nothing has worked. Plz respond if you have an answer or suggestion. Thanks.
Try updating the graphics driver. It may also be necessary to update the motherboard drivers and perhaps the motherboard BIOS.
The specific graphics card may not have been supported at the time the motherboard was released. And the same applies to the graphics card and it's driver.
I know for sure that I have the latest Driver for my graphics card and latest bios for my motherboard, and I am pretty sure that I have all the motherboard drivers that I need, however maybe I missed one. I am using the ASUS z370-P. If you could tell me the exact drivers I need that would be very helpful. thank you.
link to driver download page: https://www.asus.com/us/Motherboards/PRIME-Z370-P/HelpDesk_Download/
Here is an ASus FAQ on How to install and control AURA software?
https://www.asus.com/us/support/FAQ/1035210
https://www.asus.com/campaign/aura/us/index.html
The driver needed is this one. Read the FAQ above.
Version 1.05.32.02 beta 2018/01/2136.73 MBytes
Aura V1.05.32.02
Read the FAQ
Changelog:
Fix compatibility issue with latest Win10 version
Add support for ROG Strix Flare keyboard
Can install and run Aura software on laptops and any other platforms
Increase the support number of Addressable LED to 120 for each Addressable header
Improve system stability
Improve and adjust effect settings
Add multi-language support
Fix issue with Z170 Pro Gaming Aura UI not showing properly
Fix ROG Claymore flickering issue in Breathe mode
for Windows 7 32-bit & 64-bit, Windows 8.1 64-bit, Windows 10 64-bit (support depends on CPU)
