It depends. If you have a cpu that requires a dual tower cpu cooler and you want RGB RAM then go with an AIO due to the fact clearance will most likely be an issue. What's your system specs as far as what set of RAM do you plan on using and what is your cpu and case?Hi, Everyone I am looking to get a new aio cooler for my system and I want all my fans leds to sync so do i buy a aio cooler with RGB or A-RGB.
Thanks, Mane
Hi, I have fully built my system 1 year ago i was just looking for a replacement aio. and selling used aio cooler. I just wanted to know if my led's are going to sync with all my parts? and wanting to know if I should get RGB or A-RGBIt depends. If you have a cpu that requires a dual tower cpu cooler and you want RGB RAM then go with an AIO due to the fact clearance will most likely be an issue. What's your system specs as far as what set of RAM do you plan on using and what is your cpu and case?
My mistake .. I misread your post. You can sync a ARGB AIO with your case using your motherboard.Hi, I have fully built my system 1 year ago i was just looking for a replacement aio. and selling used aio cooler. I just wanted to know if my led's are going to sync with all my parts? and wanting to know if I should get RGB or A-RGB
Thanks, Mane
Oh no worries, Thanks for the reply I see that you can sync a-rgb with your case using your motherboard Thank you for helping me out.My mistake .. I misread your post. You can sync a ARGB AIO with your case using your motherboard.
Example.
https://www.arctic.de/us/Liquid-Freezer-II-360-A-RGB/ACFRE00101A
Oh no worries, Thanks for the reply I see that you can sync a-rgb with your case using your motherboard Thank you for helping me out. Oh and do you know any possible aio coolers i could buy with a i7-12700KF CPU. and how do I make sure my aio cooler fits inside my motherboard?
Kind regards, Mane
Oh and do you know any possible aio coolers i could buy with a i7-12700KF CPU. and how do I make sure my aio cooler fits inside my motherboard?My mistake .. I misread your post. You can sync a ARGB AIO with your case using your motherboard.
Example.
"Inside" MB is not a problem in 99% of cases as block/pump are much smaller than tower air coolers. It has to have mounting kit for your CPU socket and have radiator of right size for your CPU to cool it properly.Oh and do you know any possible aio coolers i could buy with a i7-12700KF CPU. and how do I make sure my aio cooler fits inside my motherboard?
