Rgb Pc build HELP
TheSenpaiOfTech
Commendable
Jan 21, 2017
59
I am looking to build my first gaming pc as i have been playing on a £400 pound laptop with about 20 fps on games like overwatch. I want my new pc to look cool, but run games at ultra settings on 1080p. I would like it to be rgb and my budget is £800. Before I build it I am going to wait for rizen but still put in an Intel chip. This budget includes a monitor, keyboard,os,wifi and headset. Thanks
Here's one build close to your budget without RGB.
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor (£106.99 @ Aria PC)
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard (£54.99 @ Ebuyer)
Memory: Crucial 8GB (2 x 4GB) DDR4-2133 Memory (£52.55 @ BT Shop)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£42.12 @ Aria PC)
Video Card: Gigabyte Radeon RX 480 4GB G1 Gaming Video Card (£161.94 @ Aria PC)
Case: Corsair Carbide SPEC-M2 MicroATX Mid Tower Case (£58.47 @ Amazon UK)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply (£70.80 @ Alza)
Operating System: Microsoft Windows 10 Home Full 32/64-bit (£83.94 @ Ebuyer)
Wireless Network Adapter: Gigabyte GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter (£25.90 @ Amazon UK)
Monitor: BenQ GL2460HM 24.0" 1920x1080 60Hz Monitor (£122.92 @ Amazon UK)
Keyboard: Logitech K120 Wired Standard Keyboard (£12.84 @ More Computers)
Headphones: Logitech G230 Headset (£34.99 @ Amazon UK)
Total: £828.45
Generated by PCPartPicker 2017-02-20 16:26 GMT+0000
As far as RGB fans go, you have 3 choices:
1. Go with Thermaltake and their Riing RGB 120/140 fans.
1. Go with Corsair and their SP120 RGB or HD120 RGB fans.
2. Go with NZXT and their AER RGB 120/140 fans with HUE+.
Here's what you're looking at price vise per 1 fan,
pcpp: http://uk.pcpartpicker.com/products/compare/7JnG3C,GwCrxr,w7RFf7,69Gj4D/
Best eyecandy can be achieved by NZXT HUE+ since HUE+ has 2 channels and per channel, it supports 4 LED strips (10 LEDs per strip) or 5x AER RGB fans (8 LEDs per 1 fan).
But eyecandy, especially in RGB form, comes with premium price.
I have NZXT AER RGB140 & HUE+ inside my Skylake build (full specs in my sig). And i'm currently in the process of obtaining LED strips for my Skylake build. Here are few pics of my Skylake build if you're interested: http://www.tomshardware.co.uk/forum/id-3272328/show-newest-system-upgrade-components/page-2.html#19277195
CPU: Intel Pentium G4620 3.7GHz Dual-Core Processor (£92.99 @ Amazon UK)
Motherboard: Asus PRIME B250M-A Micro ATX LGA1151 Motherboard (£72.00 @ Aria PC)
Memory: G.Skill NT Series 8GB (2 x 4GB) DDR4-2400 Memory (£52.37 @ Amazon UK)
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card (£169.98 @ Novatech)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply (£49.86 @ Ebuyer)
Monitor: AOC G2260VWQ6 21.5" 1920x1080 75Hz Monitor (£101.82 @ Aria PC)
Keyboard: Thermaltake Commander Bundle Wired Gaming Keyboard w/Laser Mouse (£23.03 @ Eclipse Computers)
Headphones: Kingston HyperX Cloud Headset (£49.98 @ Ebuyer)
Other: CiT F3 White Midi Gaming Case With 12cm Blue LED Fan & Black Stripe (£20.70 @ Eclipse Computers)
Total: £784.69
Generated by PCPartPicker 2017-02-20 17:39 GMT+0000
You'll have to make due with Black/White + Blue LED for now, unless you want to sacrifice vital gaming performance parts for RGB parts.
MSI RX480 + AOC FreeSync Monitors combo.
ASUS B250M-A together with Kabylake Pentium 2C/4T, support the faster 2400Mhz DDR4; B250 chipset support the fastest storage tech NVMe M2 SSD.
Corsair CXM 450W provide good&stable power + it's semi-modular allows better cable management. Especially if you're going to add more components like the HUE+ for RGB parts. You can see the HUE and the GRID fan controller inside the orange version of this case over at PCPP.
The Kingstone HyperX Cloud practically dominate 99% headphones in its price range.
