Hi, I wanted to build a pc that includes rgb lighting and was wondering if this pc would be good for it. I chose the dark case so that the rgb lights would pop against it. Would it work with the gigabyte motherboard as well as all the included stuff?
https://pcpartpicker.com/list/ZxRZRJ
If there is something that would make it better for about 20-50$ more, I will consider putting it into the build as well.
Thanks!
Thanks!
