Question RGB Splitter Cable Repurpose
ThrashLG
16
Hey everyone!
I can't seem to find a straight answer on the internet anywhere.
I have an RGB splitter cable 1-6. It is Female to female but with 6, 4 pin adapters to plug in to make the 6 splits male.
My waterblocks are argb (3pin) female so there is a blanked out connection stopping the male adapter connection.
I want to avoid buying new cables so I plan to snip the adapters at the same configuration as the argb. Then I plan to plug the cable into the 5v argb motherboard header.
Would this work?
