I just acquired an Intel SC5299DP Server chassis with and intel S5000XVN/XSL mainboard. I have both the standard 6-bay drive cage and the 6-bay Intel AXX6DRV3GEXP expander backplane hot-swap cage to choose from.
I plan to use 6gbs SATA drives with either cage setup but I am unsure of which setup would be best performance wise. I plan to run FreeNAS so I do not need hardware raid.
The main motherboard has 6 SATA connections (3gbs only). The expander backplane requires a raid/sas controller card to communicate with the mobo and per the FreeNAS forum, they recommend the IBM M1015 Raid/SAS card which supports 6gbs drives. I relize that since the backplane only supports 3gbs I would not be able to take advantage of the 6gbs raid card speeds. However, I did read that the SATA ports on the main board rarely perform to the 3gbs speeds which makes me reconsider using the backplane cage and a raid card vs the standard cage with sata to sata connections to the main board.
Question 1> Is there a performance boost between sata to sata connections with the mainboard vs raid card to backplane SAS connections? I realize that in either setup I will be limited to 3gbs support.
Question 2> Would using a raid/sas controller card (IBM M1015) with minisas to SATA hard drives connections, both supporting 6gbs transfer speeds be the most optimal setup?
Question 3> Since this is only going to be a home NAS server, is there any reason to worry about 3 vs 6 gbs transfer speeds?
