Hello Everybody,
So I recently got my hands on the EVGA GTX 1080 Ti FTW 3 and I am having a really hard time figuring out what is going on with my benchmark on Ghost Recon Wildlands or GPU for that matter. my fps stays stagnant between 20-25 sometimes reaching a low of 18 fps, here are my benchmarks with the graphics setting:
Ultra Settings 3440x1440 (100 Hz):
Ambient Occulsion: HBAO
Anisotropic Filtiring: 16
Anti-Aliasing:Temporal AA
Display Mode: Full Screen
Draw Distance: Very High
God Rays: Enhanced
High Quality DOF: ON
Lens Flare: ON
Level of Detail: Ultra
Long Range Shadows: Off
Resolution Scaling: 1.00
Shadow Quality: Very High
Terrain Quality: Ultra
Vegetation Quality: Very High
V-Sync: off
Benchmark Results:
FPS: CPU Usage: GPU Usage:
18.18 min 25.42 max 12.5% min 31.2% max 97.3% min 99% max
22.47 21.1% 98.7%
Also, I get this fps on average even when I lowered the settings to medium. It just wont budge from the 20's (Never seen it hit 30 fps). I also get micro stutters, borderline macro stutters
My PC Specs:
Monitor: Asus PG348Q Nvidia G-sync ON, 100Hz OC (also tried bringing it to 60Hz with g-sync off- no change)
MOBO: ASUS X99 A-II
CPU: Intel i7-6800k OC to 4.3 Ghz
PSU: EVGA 1200GQ
GPU: EVGA GTX 1080 ti ftw3
Cooling: Thermaltake Pacific Rl360 liquid cooling with acrylic tubing
Case: Thermaltake core P5
RAM: Corsair Vengeance 32GB
Storage: ADATA SU800 SSD 512GB
What I have already done:
1. Used the DDU program to wipe away AMD drivers (previously owned a radeon r9 295x2 XFX) and multiple times reinstalled NVIDIA drivers over and overt again.
2. Upgraded to windows 10 creators build (someone in the forum said it helped solve his problem with the gtx 1080 ti)
3. Turned off V-sync from nvidia control panel also and turned off the share button on geforce experience
4. Tinkered with EVGA Precision XOC. Kept all fan curves at 70% which is really loud and only achieved a fps of 28 no more.
5.Tested out the benchmark on Attila:total war and I am getting an average FPS of 22 (Performance settings), more worse than my r9 295x2
What I want to do next but need confirmation:
I've been reading up on my X99 A-II manual and noticed an interesting thing, turns out the slot I have the card in is a PCI-e Gen 2.0 x16 and the slot close to the cpu is PCI-e gen 3.0 x16. should I move it to the PCIE 3.0 slot? I've read on some forums that it doesn't increase performance, only like 1 or 2 fps and 3.0 Gpu's are backward compatible, but I'm starting that maybe I'm a different case.
Plus I can't get the screen to show anything when I put my stock riser cable to that slot, I'm assuming I need to go in my bios also to tinker with the PCH configuration or maybe put it traditionally without the riser cable since the cable might be 8 pin (x8)?
Please let me know what you think and I apologize if I didn't include any other information (let me know).
P.S I can provide you with Firestrike 4k Test result if need be, for I dont buy latest games other than Wildlands.
Thank you in advance
Solved!!!!!!! I Put the Video Card in the primary slot without the riser cable extension. to all owners that own a thermaltake core p5 case, put in your video cards how they should be put without that cable, it's cancer to amateur buildings like me and threw me off at first
God Rays: Enhanced
Lens Flare: ON
V-Sync: off
Benchmark Results:
22.47 21.1% 98.7%
My PC Specs:
MOBO: ASUS X99 A-II
PSU: EVGA 1200GQ
