• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Right-click in Start menu disabled
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Until very recently, I could go into "All Programs" in the Start menu,
right-click somewhere, and then left-click on "Sort by name" to arrange
the program icons in alphabetical order. Now for some reason, nothing at
all happens when I right click on any part of the Start menu. I have no
idea what my have happened, or what I could have done, to cause this to
happen. Any suggestions as to how I may be able to restore this
function? (I'm using XP Home, SP2).
Thanks...ncSkeet
G
Guest
Guest
If your right click menu is missing.....
XP Start Menu >>
Right click the Start button | Properties |
Start Menu tab | Customize button | Advanced tab |
Scroll down to and Check: ? Enable dragging and dropping |
OK | OK
[[Specifies whether you can drag items to the Start
menu.]] Also disables right click menu if UNChecked.
If XP Pro...
You can use the Group Policy editor (Gpedit.msc) under the following
location to configure Start menu features:
User Configuration \ Administrative Templates \ Start Menu and Taskbar
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\
Policies\Explorer
The registry entries are DWORD values. A value of 1 is enabled, and a value
of 0 is disabled.
Policy: Disable drag-and-drop menus on the Start Menu
Description: Prevents users from modifying the Start menu by dragging and
dropping items. Other methods of customizing the Start menu are still
enabled.
Registry Value: "NoChangeStartMenu"
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:O$shqHGRFHA.904@tk2msftngp13.phx.gbl,
ncSkeet <TheBe@les.kom> hunted and pecked:
> Thanks...ncSkeet
G
Guest
Guest
> XP Start Menu >>
> OK | OK
That did the trick...many thanks. I wouldn't have known to check that
when I first noticed the missing right-click menu. I must have unchecked
it by mistake somehow.
Thanks again..ncSkeet
G
Guest
Guest
You bet, ncSkeet. Keep having fun. :)
Wes
In news:etdk$uIRFHA.3788@tk2msftngp13.phx.gbl,
>> XP Start Menu >>
>> OK | OK
Similar threads
