Right click menu
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Win XP Home
After installing fresh programs I find that some are
featured in the menu which appears when I "Right Click"
Also shown are some programmes which I have deleted.
Is there a way to edit the list shown when right click is made. ?
kgm
Hi,
Click start/run, type regedit and click ok. The entries are under these keys
(which depends on where you are seeing the context menu):
HKEY_CLASSES_ROOT\*\OpenWithList
HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers
HKEY_CLASSES_ROOT\Directory\Background\shellex
HKEY_CLASSES_ROOT\Directory\shell
HKEY_CLASSES_ROOT\Directory\shellex\ContextMenuHandlers
HKEY_CLASSES_ROOT\Drive\shell
HKEY_CLASSES_ROOT\Drive\shellex\ContextMenuHandlers
HKEY_CLASSES_ROOT\Folder\shell
HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"kgm" <justins@TAKESOCKSOFFsidcliffe.wanadoo.co.uk> wrote in message
news:clrhee$qdd$1@newsg3.svr.pol.co.uk...
> Win XP Home
> kgm
Right Click Context Menus - Deleting entries
Customizing Right-Click Menu Options in Windows
http://www.jfitz.com/tips/rclick_custom.html
ContextEdit lets you control which items appear on your context menu
(right-click) in Windows Explorer.
Add, Modify, Disable, Delete Context Menu Listings (Line 23)
http://www.kellys-korner-xp.com/xp_tweaks.htm
"kgm" wrote:
> Win XP Home
> kgm
Thank you both for prompt and relevant answers.
kgm
> Win XP Home
> kgm
