Right-click on- my computer icon- take long time to load
t21
340
Hello,
well these problem came recently while i right-click on (my computer) to go to manage or properties it's only happens on my computer icon
all files and icons open fast but these one(my computer) take long time to load
any help would be very appreciated
NOTE: i did try to clean install but the problem still exist
I suggest threatening and if that doesn't work hit it a few times, and the last step is cleaning out the dust
next is running mem test
http://www.memtest.org/
if you pass that put new thermal paste on the cpu if that fails format the drive before you reinstall windows
after that you should throw it away
preferably out a window from at least 3 stories up.
