Right earbud no longer works on my roxx orbit. What should I do?
Oct 4, 2018
Base is fully charged and the left work just fine but not my right ear piece please tell me what I should do to get it working on the right.
Try the earphones on another audio source.
Try other earphones on your current audio device.
Determine if the problem follows the earphones or stays with the audio device.
Another test: plug in the earphones as normal and listen while you gently twist, wiggle, and pull the connecting wires. Especially around the right ear piece.
You may discover that there is a bad connection. May or may not be repairable.
