Question Right Headphone Not Working
Aug 11, 2019
13
Hi everyone,
I have a MSI GE72PRO Apache Pro, My right headphone isn't working for some reason, The jack isn't bent or anything, but when I do insert the headphone 2/3 of the way in the right headphone works. please help.
those headsets are 4pole jack, u may want adapter for it
something like this
Aug 11, 2019
13
something like this
im already using that and I tried not using it and I tried different headphones
Aug 11, 2019
13
hey this is still a problem for me and my teammates are getting really mad at me when I don't hear something to my right. plz help
The issue is that the Xbox controller most likely has a sound chip built into it that splits the single input, where as your PC has separate inputs for each, neither of which can correctly process the mixed input.
The solution is to either get an adapter, or a USB soundcard that supports mixed input.
Can you verify the headphone port on your PC works correctly with another headphones?
Aug 11, 2019
13
i did some googling, some adapters will work, some not
what will definitely work is that u connect xbox controller with your PC (usb cable), than u connect headphones to xbox controller
With or without the adapter it still doesn’t work I don’t think it's the adapter and I tried using the Xbox controller jack through usb and that still didn’t work it also doesn’t work with any other headphones
