[SOLVED] Right power connectors for gpu?
If this is your psu:
https://www.newegg.com/Product/Product.aspx?Item=N82E16817153166
Then it has the proper connectors, namely a 6 pin and a 8(or 6+2) pin connector.
But, be advised that the psu is considered as a tier7(worst ) unit on this list:
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
The newegg reviews are not good either.
It should be ok in theory, but I would give serious thought to buying a good quality replacement.
The danger with a poor psu is not that it might not work properly, the danger is that if it should fail under load, it might not have the protective circuitry to protect your other parts from damage.
Seasonic is always good, I like the new focus line. 550 or 650w is good.
I actualy ment this one
http://
