Right Speaker No Sound....
TheDogManiac02
17
Hi everyone,
i have a problem with my speakers. This is the speaker:
Speedlink Jugger 2.1
I have it since February 2014.
And it is not the pc, because i tested the Headphones and there was sound from left and right. And i connected my headphones to the speaker aswell and it worked left and right too.....
Well the right speaker works again! But i'll leave this thread open for if the problem returns...
The Speaker is connected to my PC.
Is my speaker broken?!
If anyone can help, pls help!
Well, guess what? The problem returned.... I changed the cables up (so the speaker on the right was on the left) and now the left speaker has no sound.... so it is the subwoofer thing.
i will try it but i have no time right now. what i also dont get is, how do you open these speakers? And there is sort of a hole in both speakers and when you look in, you see a metal plate.....
I have that problem currently. For me it has to do with the little thing that plugs into the audio jack. There is a short in the wire or something like that so if you wiggle the cord right where it goes into the piece that plugs into the jack, you can sometimes get it to work again. This isn't necessarily what you have though.
but with rca cable, do you mean from the pc to rca or from the speaker itself (the big blocky subwoofer thing) to the right little speaker?
but you do know that the left speaker has a white rca, and the right speaker a red rca right?
so can i just change them up?
well i plugged the speaker out for an hour or so, then i plugged it back in and voila.... it WORKS AGAIN!!!!
I am gonna leave this thread open, because i just know, this isnt over.....
No, but I will do it tomorrow. At my place it is 12:42 am so I'm going to sleep now.
i just found out that that doesnt work.... The Rca cable is connected to the sound leveler, and the sound leveler to my pc.....
Well, the problem returned, i changed the cables and voila! It is now finally fixed. Thx for your awesome help iknowhowtofixit! You sure do know how to fix it! xD
well i am glad that the problem is gone, but now the next one appeared....
Now my right speaker makes a buzzing sound when someone talks on a video....
Take Ashens for example: He says something and the right speaker has a low buzzing sound which gets on my nerves really quickly. Have any idea what this could be?
Update: I narrowed the problem down to the red contact in the subwoofer! If i change the two speakers up, the problem is now on the left and not the right. So if i put the white cable in the red contact the buzzing is in the left speaker and not the right one.
the buzz is still there...... what is a ground loop isolator?
But the buzzing is only when someone on a video is talking..... and it is like synchronized with the talking of the Person.....
The voice becomes less clear and it is like you are using really bad headphones.
