PSU - Seasonic G-550 80Plus Gold
GPU - GTX 970 (zotac blower version)
bought all last year-earlier this year.
This was my connection before,that two ends in the right are 6pins(provided in the GPU) so its connected to the gpu and the left end is connected to the psu. I only bought the molex adapter/extender separately.
its like this => peripheral in psu -> peripheral 4 pin(3) || -> molex -> 6pin(gpu)
|| -> 6pin(gpu)
I was cleaning up my room earlier and came across the box of the psu and I found there were two psi-e 8/6 pin connector inside (i thought that psi was only one,thats why I bought a molex)...so I decided to try that two on to lessen the wires inside my case.
(2x)psi-e/cpu part in psu -> psi-e 8/6 pin connector -> gpu
now the question is there a difference between the two set up? or still it doesn't matter if I didnt do the second set-up and remained with the peripheral connections?
by the way, I have this random problem during playing games that my monitor would just turn off but pc still running (second monitor that is connecting to the motherboard still have the desktop on it) ...is this the problem caused by having the first set up?
|| -> 6pin(gpu)
