I'm planning on buying Bitspower G 1/4" Carbon Black Enhance Multi-Link for OD 12mm (https://shop.bitspower.com/index.ph...ct&product_id=1023&search=carbon+black&page=5) , but in the description it says "via acrylic tube". Can I use PETG tubes (https://www.performance-pcs.com/wat...m-od-tube-length-1000mm-bp-ncplt12-l1000.html) on these fittings?
Also, How many PETG tubes would you buy for first time building hard tube loops ( 500mm x amount or 1000mm x amount)?
Specs:
-Lian Li PC-O11 Dynamic
-MSI RTX 2080 SeaHawk EK X (using vertical mount)
-EK-Supremacy MX WaterBlock
-EK-CoolStream SE 360 (Slim Triple) (on the front back panel)
-EK-CoolStream PE 240 (Dual) (on the top) )
Thanks!
Specs:
Thanks!
