Riotoro Morpheus GPX-100 Review: Forward-Looking Design, Some Assembly Required
  • Thread starter Thread starter Guest
  • Start date Start date
As noted in the review, the dust filters work great and are easy to clean. Also, the system noise was in line with all the other cases we tested against.
Is the difference between a mini and a mid tower only two inches normally? That's the difference in the dims listed here between the two. Maybe it's on the large side for a mini or smaller side for a mid?
@jasonsrevell you are correct on both counts. The chassis is a little big for a mini, a little small (outward dimensions) for a mid-tower. It is the perfect blend between the two.
