RIS problem (or No RIS is the problem)
Brad
497
Archived from groups: microsoft.public.win2000.setup_deployment (More info?)
One of our regional RIS boxes no longer works. The client PCs boot
from NIC and do receive an IP, but then the screen goes black instead
of the blue setup screen. Recent changes to the server were this
SP4, KB837001, 828741, 835732, 823559, 820888, 822831.
The last successful RIS was 3 days before these patches and SP. Has
anyone experienced any issues with these patches and RIS servers?
Thoughts?
Thanks
Hi Brad:
I've not seen anything about the latest round of patches breaking RIS.
As a test you may want to put down another image on the RIS server and see
if that one deploys successfully.
You can do this by running Start/Run and then RISETUP -ADD. You may also
want to run an RISETUP -CHECK to have the RIS components examined and fix if
needed.
There is a video issue that are addressed in the two articles below. You may
want to investigate whether or not these fixes would address the issue
you're seeing.
Windows 2K
317863 A RIS Client Installation May Hang at the "Setup Is Starting Windows
http://support.microsoft.com/?id=317863
Xp images
319111 Windows XP RIS Client Loses Video or Stops Responding While "Starting
http://support.microsoft.com/?id=319111
If when you hit F12 on the Client machine - the WELCOME.OSC screen NEVER
comes up, try to simplify the connection between the client and the RIS
server. Ideally, try putting the client on the same local subnet as the RIS
server. If the client is requiring connections and communications through a
switch or router, make sure the required ports have not been closed by
either the patches or by another administrator.
832017 Port Requirements for the Microsoft Windows Server System
http://support.microsoft.com/?id=832017
Remote Installation
You can use
the Remote Installation system service to install Windows 2000, Windows XP,
and Windows Server 2003 on Pre-Boot eXecution Environment (PXE) remote
boot-enabled client computers. The Boot Information Negotiation Layer (BINL)
service, the primary component of Remote Installation Server (RIS), answers
PXE client requests, checks Active Directory for client validation, and
passes client information to and from the server. The BINL service is
installed when you either add the RIS component from Add/Remove Windows
Components, or select it when you initially install the operating system.
System service name: "BINLSVC"
| Application protocol | Protocol | Ports |
| BINL | UDP | 4011 |
Trivial FTP Daemon
The Trivial FTP Daemon system service does not require a user name or a
password and is an integral part of RIS. The Trivial FTP Daemon service
implements support for the Trivial FTP Protocol (TFTP) that is defined by
the following RFCs:
RFC 1350 - TFTP
RFC 2347 - Option extension
RFC 2348 - Block size option
RFC 2349 - Timeout interval, and transfer size options
TFTP is a file transfer protocol that is designed to support diskless boot
environments. TFTP daemons listen on UDP port 69 but respond from a randomly
allocated high port. Therefore, when you enable this port, the TFTP service
can receive incoming TFTP requests, but enabling it does not allow the
selected server to respond to those requests. You must configure the
selected server to respond from port 69 to allow it to respond to inbound
TFTP requests.
System service name: "tftpd"
| TFTP | UDP | 69 |
If this information doesn't wind up helping you figure out what's going on,
please contact our Platforms Setup team via the phone and get a case
created. We'll be glad to assist you in tracking down what the problem is.
This posting is provided "AS IS" with no warranties, and confers no rights.
Please reply to the group as individual email sent to this address will not
be delivered.
"Brad" <none@themoment.net> wrote in message
news:9cnn90hgnevo02871tde9l7pgmmisnm2ln@4ax.com...
: One of our regional RIS boxes no longer works. The client PCs boot
: from NIC and do receive an IP, but then the screen goes black instead
: of the blue setup screen. Recent changes to the server were this
: SP4, KB837001, 828741, 835732, 823559, 820888, 822831.
: The last successful RIS was 3 days before these patches and SP. Has
: anyone experienced any issues with these patches and RIS servers?
: Thoughts?
: Thanks
Thanks Sean, I'll look into these things. Due to security, I can't
move PCs or servers, and different departments operate switches
between sites so it might be port related. There is NO video after
hittig F12. There are also multiple images, so adding a new one won't
help. RISETUP -CHECK came up as all fine.
On Fri, 7 May 2004 16:25:26 -0400, "Sean Dwyer[MSFT]"
<sdwyer@online.microsoft.com> wrote:
>Hi Brad:
>needed.
>you're seeing.
>Windows 2K
>Xp images
>Remote Installation
>You can use
>| BINL | UDP | 4011 |
>Trivial FTP Daemon
>the following RFCs:
> RFC 1350 - TFTP
>TFTP requests.
>| TFTP | UDP | 69 |
I had problems with the 835732 patch. After integrating
in to the CD based image(KB Article 828930), everything
worked fine. My error had to do with the CD image not
matching though.
>-----Original Message-----
PCs boot
black instead
were this
and SP. Has
servers?
>Thoughts?
>Thanks
