Archived from groups: microsoft.public.win2000.setup_deployment (
More info?)
Well when I've come across that problem before, I have managed to delete the
files by using the del command in the command prompt. For some reason,
Windows Explorer doesn't seem to like the path to the files.
You can solve the incorrect NIC problem by adding the correct driver files
into the i386 folder of the CD-based image. These will usually be a .sys
file, a .cat file & an .inf file. I have found also that some drivers that
are included in the base image do not support some newer NICs & need to be
updated with newer versions of the .sys file (rename the old one *.old
instead of deleting it just in case!). Once new driver files are placed in
the i386 folder, restart the BINL service on the DC & when you first try to
connect to the RIS server using the new drivers, you should see the .inf
files compiled into .pnf files with the same name.
"nopcl" <nopcl@discussions.microsoft.com> wrote in message
news:948D43D6-C542-47A7-B7B5-6582B51D0FBC@microsoft.com...
> i was able to correct the error message by restoring the template files on
> the cd image, but still cant kill those crypto keys. The system is in poor
> service anyway, with dozens of stale images and duplicates, they actually
> were running out of room on the server. Yes they keep the cd images with
the
> ris images, and they also use this server as a DC. Now the "test" xp
images
> they were working on are coming up with the infamous "image doesnt contain
> the correct nic driver"......i suspect this will be ongoing...LOL. But any
> suggestions on how to kill off those last RSA files will be apprectiated
> B
> "Chris" wrote:
> > You are quite right about the Single Instance Storage Groveler service
which
> > scans SIS volumes for duplicate files, but the 'files' you see in the
file
> > system for the images where this service is run are not the master
copies of
> > the file, just pointers, so you wont delete the original.
> > "Daniel" <anonymous@discussions.microsoft.com> wrote in message
> > news:370901c4aa2e$ca47fef0$a401280a@phx.gbl...
> > > A couple of points:
> > > 1. The RIS server uses something called a grovler, which
> > > steamlines the RIS volume by eliminating redundant data.
> > > This means that it does not keep multiple copies of the
> > > same file. If some files are eliminated, then it may
> > > interfere with the deployment of images.
> > > 2. All RIS images are dependant on the initial CD-based
> > > image which was used to create it. If there are any
> > > modifications which are made to the CD-based image, the
> > > all of the correstponding RIS images can potentially fail
> > > to deploy.
> > > What this means:
> > > 1. a. If there were files deleted from the RIS volume,
> > > then they were most likely originals.
> > > 1. b. Why exactly were they trying to "make space" I fear
> > > that they kept the RIS images on the same volume as the
> > > system. Is this fact?
> > > 2. If the CD based image is in anyway modified, then the
> > > RIS images won't work. Are the RIS images able to be
> > > deployed?
> > > Daniel
> > > >-----Original Message-----
> > > >New to a company and trying to fix all their
> > > problems....;-)
> > > >first is that when trying to delete a bunch of stale
> > > images, i get an error
> > > >referencing a crypto key buried in the image. The error
> > > states the file isnt
> > > >there, and it refers to a different file for each image
> > > so its not a single
> > > >use problem.
> > > >The second is that since the sys admin tried to delete
> > > some files to make
> > > >room on the RIS server, i get an error "unable to find
> > > message text 1%* **and
> > > >corresponding message text 2%**, and am unable to upload
> > > any new images ??
> > > >any help would be greatly appreciated as this is one of
> > > several piles on my
> > > >plate..
