RIVA TNT 2 Problems
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I'm getting "flashing" graphics in some older games ever since updating my
TNT 2 drivers. I'm using this cards with Windows 98. Any idea what the
problem could be or what settings I can adjust?
Thanks,
Aphelion
"Aphelion" <sonship@twcny.rr.com> wrote in message
news:ToUrc.75172$hY.5864@twister.nyroc.rr.com...
> Thanks,
> Aphelion
You answered your own question...."ever since updating my
> TNT 2 drivers"
Go back to what you were using b4. There is nothing you can gain by
upgrading the drivers on that card running that OS. BUt as you have found,
there are things you can lose. >
found,
Yeah... good idea. How do I reset the old driver? I remember having a
"roll back" feature at one point, but now it's non-existent.
Aphelion
there is no rollback feature in win98 - you uninstall the new drivers and
reinstall the old ones. the 12.41s should be fine from www.guru3d.com
news😱3Wrc.240523$M3.226096@twister.nyroc.rr.com...
> found,
> Aphelion
Well, I downloaded 14.13.01's from nVidia, and the graphics problem is
solved. HOWEVER, now, the sound in most games is choppy. WTF!
Btw, I basically just downloaded and installed over the old drivers. Is
that wise? Like I said, so far no graphics problems. Can I attribute that
to the sound problems perhaps?
Aphelion
is this dumbarse for REAL ?, you should uninstall your drivers before
installing drivers over them, if you did not know this, sorry Dumbarse
On Sun, 23 May 2004 11:04:47 GMT, "Aphelion" <sonship@twcny.rr.com>
>Aphelion
If you are using the 5x.xx drivers with that older card, it will not work
correctly. Those drivers aren't stable with that non-FX card.
DaveW
> Thanks,
> Aphelion
Hey, if everyone who needs the answer to a question is a dumbarse, why do
Newsgroups exist?
Shouldn't they be called "Dumbarse groups" and be avoided by incredibly
intelligent Computer Gods like you :)
From
A.Dumbarse.
"We Live for the One we Die for the One" <Mr fred@yahoo.com.au> wrote in
message news:9f10b0hkku7jko51i0j0235tt74ir5ong4@4ax.com...
and
that
> >Aphelion
