RM650 PSU Fan Not Spinning on Startup, or at all.
TheGaranimal
Hey All,
I just built a new computer with a buddies older Corsair RM650 Power Supply and the fan of the power supply is not spinning on startup. I understand that the fan will not spin until i put it under 40% load but I am just wondering if it is supposed to spin on startup as a sort of "check" that it is in working order or if it is normal for it to not spin at all until under a strong load.
My specs:
Intel i7 7700k
MSI h170 Gaming Mobo
Gigabyte radeon r9 280
evo 212 CPU cooler
WD 500 gb SSD
Vengance 2x8 DDR4 3000
Thanks in advance.
The Corsair RM650 is fully modular and optimized for silence and high efficiency. It’s built with low-noise capacitors and transformers, and Zero RPM Fan Mode ensures that the fan doesn’t even spin until the power supply is under heavy load. And with a fan that’s custom-designed for low noise operation, it’s whisper-quiet even when it’s pushed hard.
