Hi guys,
I'm setting up a wireless roaming network in my house to extend my signal with as little speed/bandwidth loss as possible. I'm using an Airport Extreme 802.11n (4th gen) as the base and an Airport Express 802.11b/g (original) as the bridge. They are connected via a 5 port ethernet hub, an Asanté FriendlyNet FH10T5. There is also a TV media center connected via ethernet to the hub. All the wiring is either cat5e or cat6.
The problem is that the hub is only giving the bridge about 1/4 of the bandwidth as the base gets, both over wireless and ethernet. Also, the "collision" light on the hub is frequently flashing. Is this typical of an ethernet hub? Would an ethernet switch remedy this?
Thanks,
JGAN
Thanks,
JGAN
