Rock Candy Wired PS3 Controller
TheNerdGod86
Commendable
Dec 14, 2016
I have a wired Rock Candy PS3 controller made by PDP when I connect it to my PC it shows up and I am able to test it with the controller properties all the buttons work fine but when I try to play any games It doesn't let me use the controller
Is there any way I could trick Windows into thinking my wired controller is a Xbox 360 controller like what Motionjoy and ScpServer does with the DS3 controllers?
I have
Windows 10 Pro X64
4GB DDR2
Intel Dual-Core CPU E5300 2.60GHz
1GB AMD Radeon HD 5450
You can do some searching on the net to see if there's any way to do what you want to do. But I'm not so sure if you can really trick it to think it's a 360 controller.
