Rookie System Builder - Need Some Help
kshah
9
Hi All -
I appreciate your help in advanced.
I am upgrading from my almost 4 year old Dell (E6400 Core 2 Duo / 7900 GTX) as it's been giving me a ton of problems lately and I think its time to move on :bounce:
The basic use of my computer is World of Warcraft / MS Office / Some minor editing of video (FRAPS) / music, movies, etc... nothing too extreme or out of the ordinary.
I've been looking around for a month or so now trying to come up with a list of parts I think may serve my needs and this is what I've come up with - I am really afraid I may be under or overshooting for the overall computer needs I have or possible picking incompatible parts, so any guidance would be awesome. I am trying to stay under $1400 if possible - under would be awesome if I can get away with it. The current parts I have picked are sub $1000 - but I need to still grab a monitor.
Please critique away!
Thanks again.
AMD Phenom II X4 940 Deneb 3.0GHz Socket AM2+ 125W Quad-Core Black Edition Processor Model HDZ940XCGIBOX - Retail
GIGABYTE GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD Motherboard - Retail
SAPPHIRE 100259-1GL Radeon HD 4870 1GB
(2) G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory = 8 GB Total
OCZ Fatal1ty OCZ550FTY 550W ATX12V / EPS12V SLI Ready CrossFire Ready Modular Active PFC Power Supply - Retail
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive - OEM
COOLER MASTER Centurion 590 RC-590-KKN1-GP Black SECC / ABS ATX Mid Tower Computer Case - Retail
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - Retail
LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders - OEM
The CM 690 is a big upgrade on the case for another 10 bucks:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
As Shortsuff says, the Corsair 750TX might be good for you.
If you are sticking to a single card, this BFG LS-550 is probably the better PSU:
(edit: Ooops I don't mean better than the Corsair, I mean better than the OCZ you picked)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817702008&Tpk=BFG%20LS-550
Or, for higher quality:
Corsair 550VX
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004&Tpk=550VX
You won't see any difference in gaming with 8GB over 4GB of RAM. Minor video editing doesn't warrant the extra 4GB.
Given those adjustments, you COULD upgrade to a PII 955 or even an Intel build... but you would likely be happy with that and save some.
Thanks for the responses.
I've switched to the Corsair CMPSU-750TX per recommendation by shortstuff_mt, and I have also opted to get only 1 of the RAM kits per Proximon's adjustment. I have also switched to the CM 690 case - thanks!
Anyone else have any ideas to tweak the build?
I was just about to order this when I read on a few forums about problems with the 4870 and World of Warcraft - can anyone who has a Phenom II 940 + 4870 card comment on how WoW works if they happen to play it? :)
Proximon -
What started my search was the last review for the 4870 1Gig Sapphire I was going to go with
"I get as low as 4 fps to 40 fps in World of Warcraft for which I bought the card. There seems to be a compatibility issue with Wow and the card/drivers. Tried old/new drivers and everything in between to get results to no avail."
I then searched google for some more info and came across this thread in the WoW forums concerning performance issues with 4850/4870s and WoW which is where I started to get concerned :)
These had posts going up to April of 2009 so it seems to be a current issue?
http://forums.worldofwarcraft.com/thread.html?topicId=11829372874&sid=1&pageNo=30
I just don't want to spend a lot of money upgrading and then not be able to play as well as I could on even my old PC
In Dalaran with about 50 people on the screen, running around and jumping like they do 😛
Average 40 FPS with one droop to 34, and as high as 52.
This is with around 80 installed mods
1680x1050
EVERYTHING set to high detail.
E8400 @ 3.6Ghz
P5Q-E
4GB CAS 4 800mhz RAM
Sapphire 4870 512MB Toxic edition
Corsair 750TX
You sure are spending a lot of money to play WoW. You could probably get away with spending a lot less , and only spend around 800 bucks , 600 if your REALLY lucky. E-mail me at Drudicta@hotmail.com if you'd want it down that low ,it wont be the best , but it will play WoW at its best, and do your video editing.
It's not hard to put thermal paste on. ^^; You just put a little on your finger , what I call a "dab" and spread it on the processor being careful not to touch the edges so it doesnt go over , and make sure you use a small enough amount that its paper thin. Not that difficult. You made it seem way harder then it is. ^^; But not as hard as those instructions did. lol.
hey guys - as an update I was about to order the AMD system this morning when I noticed this really good deal for a
GIGABYTE GA-EX58-UD3R Core i7/ Intel X58/ DDR3/ CrossFireX/ A&GbE/ ATX Motherboard + Intel Core i7 Processor i7-920 2.66GHz 8MB LGA1366 CPU, Retail for $400 combo..
So I am thinking it may be better value for me to spend the extra $100 and upgrade to the i7 build from the Phenom II x4 940
here are my other parts - mostly the same - please let me know what you guys think!
LG 22X DVD±R DVD Burner with LightScribe Black SATA Model GH22LS30 - OEM
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 ... - Retail
Arctic Silver 5 Thermal Compound - OEM
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model F3-12800CL9T-6GBNQ - Retail
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
Total - $1100 :bounce:
I think you should spend the extra 10-15 bucks on corsairs 750 watt , besides It's really shiny. 😛 I felt like I got a brick of gold when I opened the thing up.
doh -- i've already pulled the trigger. Is the 750 corsair vs the 650 corsair I ordered going to cause me major problems? I don't think ill be doing dual video cards anytime in the foreseeable future
Actually, The Corsair TX650 is quieter. It's a Seasonic unit where the 750TX (which I own) is a CWT. They are both great, but the build quality is actually better on the 650. IF you are certain it's just a single card setup, then I believe the 650 is a fine choice.
ok - please noone recommend any more changes I think my head may explode! And thanks all for your help once again..I'm pretty sure I went overboard w/ the build but for $1050 all said and done I think it's okay! :)
