Rosewill Challenger with a red led fan?
Swapping fans out is one of the simplest things you will do,
unplug fan, note wiring route,
unscrew fan, put on (soon to be huge pile) shelf
get new fan, same size usually although some fanmods involve going large
feed wire through route previously used or better
affix using same points and screws,
plug into Mobo/molex
And the red fan? it will look erm, redder and less blue imo
check out the members system gallery for some red themed builds :)
Moto
Moto
