I recently purchased a Rosewill Hive Series 1000W Modular Gaming Power Supply, 80 PLUS Bronze Certified, Single +12V Rail, Intel 4th Gen CPU Ready, SLI & CrossFire Ready - Hive-1000
https://www.newegg.com/global/au-en/Product/Product.aspx?Item=N82E16817182315
I am trying to install it on an AsrockZ87 Extreme 6, which has 1 x 24pin Power connector and 1 x ATX 12V Power Connector (ATX12V1) , until I upgrade my PC.
My new Motherboard will be an Asrock X470 Master SLI, It has 1 x 24pin Power connector and 1 x ATX 12V Power Connector (ATX12V1) and 1 x ATX 12V Power Connector (ATX12V2).
The Rosewill Hive 1000s has only one 24pin CPU power input, how do I connect the 1 x ATX 12V Power Connector (ATX12V1) and 1 x ATX 12V Power Connector (ATX12V2). The EPS connectors are available on the PSU I have replaced (Zalman 750W) The Rosewill Hive comes with 2 x 8 pin 12volt connector cables but no output on the PSU. There are 4 x 6pin connectors on the supplied sata cables. Can I use these somehow? Or can I use a molex to 8 pin EPS connector from the molex connectors on the cable??
Can any one help.
