Hello,
I recently went to build a budget gaming system similar to the last 2 system builder marathon budget systems with some minor upgrades:
Rosewill FBM-01 case
Rosewill RG-630 PSU
Gigabyte H77M-D3H mobo
Intel i5-3450 CPU
Radeon HD 6870 1GB
2x4GB RAM
DVD burner
2 1TB sata drives from my previous system
I had some trouble with the power supply when I first set the system up with 1 harddrive - it wouldn't even turn on the fan when I switched it on. But after reseating all the cables a couple of times and then spending 15 minutes on the phone with Rosewill's tech support, I determined that it was working by pulling all the cables and using (on their advice) a paper clip to short a black wire to a red wire on the main 24 pin DC cable. The PSU apparently detects shorts and poorly connected cables in some way and won't power up, though there's no way to tell which DC cable is responsible. In any case, I was finally able to get the system up and running and get the OS installed and such.
Today, I tried to transfer in the second hard drive. The Rosewill case made this a bit harder than it sounds, as I had to pop out the RAM in order to slide in a harddrive, had to pull the graphics card to plug in another SATA 3 cable, and had to squeeze the second harddrive in front of the main power cable to the motherboard. When I got it all put back together, I turned it on, and, once again, absolutely nothing happened. So I reseated all the cables (which again, involves pulling components out and rebuilding), and... nothing. So I pulled everything except the motherboard DC connections... nothing. So I pulled all the cables and tried the paperclip trick... nothing.
This is the most finicky PSU I've ever worked with. Is it dead, or is it detecting a failure somewhere, or is it in some kind of lock out mode after detecting a failure? I don't know, and I'm not sure how to test...
Is this a bum PSU that I need to return? Or is this normal for the RG-630's? Has anyone else run into these issues? How easy is it to blow a PSU? Is it possible I somehow blew it in the course of pulling and reseating DC cables repeatedly (with the AC power off, of course)?
Thanks,
Jason
Rosewill RG-630 PSU
Intel i5-3450 CPU
Radeon HD 6870 1GB
2x4GB RAM
DVD burner
Thanks,
Jason
