Hello everyone, I recently upgraded (almost entirely new) my PC and everything is working great, except for I can't seem to change the RGB LEDs on my case and it's fans.
Case: Rosewill PRISM S500
https://www.newegg.com/black-rosewi...-tower/p/N82E16811147283?Item=N82E16811147283
MOBO: ASUS Prime Z790 P WIFI
https://www.newegg.com/asus-prime-z790-p-wifi/p/N82E16813119603?Item=N82E16813119603
When I bought these, I checked to ensure that the case supported Aura Sync. It says it does on the website, but upon plugging everything in, I have no control over the lights: the button on the case does nothing and Armoury Crate program doesn't see the lights even though they are on (it also doesn't show the 3 bottom fans as doing anything either, which are also running/working). From what I can gather, the case hub seems to have a 3 prong plug instead of the 4? There's the SATA power, then there is a 3 prong "IN VDG" (which I understand to be only used for a few MOBO brands and not ASUS?) which I left unplugged and a larger 3 prong (that looks like it should have 4) that I ended up plugging into the "Addressable Gen 2" headers because the Aura RGB headers are apprently 12V instead of 5V - so I am afraid to use it and not sure I even could because those headers have 4 prongs. The case is suppose to be compatible, what gives?
Edit: This guy shows the same cables I am working with:
View: https://imgur.com/gallery/6y7B6m8
