Router always needing to be reset for wireless connection to work again
Jamry
59
All direct connection still works when wireless connections like from a smartphone to a router does not work.
Temporary solution is to change the SSID of Wireless Connection on router.
But it's only temporary as the issue still remains.
Last time the longest solution was that I changed the channel width to 6.
It worked for atleast a year. But the issue is again appearing.
I would to know your thoughts about this. Thanks in advance guys.
My thought is that, proceed to troubleshooting.
First thing I wanna know is, how many radios in the neighborhood, what channels are they using, their strengths, also there should be a troubleshooting applet for your NIC that tells you signal-to-noise ratio.
