Question Router connectivity problem ?
Apr 10, 2024
Hi I have this problem with my router its connected with my andriod box and im get network from my router to my android box but as soon as I connect my desktop pc with the router then there's no internet connections. My desktop do not pickup my routers LAN connection or my router does not pickup my desktop's LAN connection.
But when i connect another router to my desktop's LAN port then it works fine, internet and all. But when i plug it in to the router that we use at home there nothing happening, no connection ?
Make and model routers?
Wired or wireless connectivity?
On your desktop run "ipconfig /all" (without quotes) via the Command Prompt.
Copy and paste the results here.
The problem you describe may be that the desktop's NIC is not not correctly configured for the network. Could also be an IP address conflict amongst the devices.
Not uncommon when multiple devices are in use and/or being moved between networks/routers.
