I currently have a NetGear WRN2000v3 that is less than a year old. It is connected to a Motorola SurfBoard 6121 cable modem and I use all 4 of the router's wired connections (two PCs that are constantly used, two PS3s with moderate use) as well as 4+ wireless connections at any given time (two Android devices, two Nintendo 3DSs). My wired connection runs around 36 Mbps down, 6 Mbps up.
I live in an apartment complex and there are a ton of other routers in my area crowded across all channels (I run Ch. 11 after using the wifi analyzer android app). Over the past two months or so, I have experienced a lot of random drops in wi-fi. The router says wireless is on, but none of my devices get a signal. Other times the router would just reboot itself randomly - this is much rare, but it does happen. Something is obviously not right with it. I should add, the router and modem are located in a middle bedroom, while the wireless devices are usually used at either end of the apartment, so there is a natural drop in signal strength, but it should not be that significant. Changing the location is not really a feasible option.
I either need to stop these drops or get a new router and send this one in to NetGear for servicing and use it as a backup. If I do get a new one, what would be best for my usage while staying $100 or less? I appreciate any advice/assistance!
