[SOLVED] Router features request for Fiber cable ?
Quast.3
Commendable
Oct 29, 2019
15
Hi.
I changed to fiber network and I want to know the main feature should router have to work good with fiber cable. What I could buy are those two routers.
  • TP-LINK WR840N
  • TP-LINK 940N
My speed is 3MB and maybe will increase it to 10MB later.
Generally an ethernet input is all that is required. With a 3Mb -- Internet speed is measured in bits (little b) -- to 10Mb WAN connection, you might want a router that has easy to use QOS to attempt to prioritize your gaming traffic.
So, Both routers can handle the speed and work good. For wireless connection is the same ? Can I get the signal after three rooms ?
Unknown for WIFI coverage. It is VERY dependent on your specific construction, neighboring WIFI interference, and device. I wouldn't recommend EITHER of those routers. They are 2.4Ghz WIFI ONLY. If you want a TP-Link get an AC1900 class router like the A9.
Reactions: Quast.3
