Router speed problem
Roni Pal
194
I have a Iball baton router. My internet connection is 2 mbps. Router speed is ok when it is connected with laptop and desktop. But when I connected it to android devices it give me 1 mbps speed. Does my router is faulty?
Please help to fix this
depends on the model. From what i have seen you likely have a wireless n router with only 150mbps wireless speeds then no your wireless is performing as should. i assume you mean you internet connection is 2MB/s (not mbps which is much slower) which would make your wireless 1MB/s which is about what you get for a 150mbps connection on wireless.
When i download from my laptop or desktop I am getting 2 mbps i.e. 256 kb/s download speed. When on android devices i am getting about 140 kb/s. When I download from the android device I make sure all the other devices are disconnected. But then also i am not getting 256 kb/s.
yeah if y our running in the low kbs then your not getting the speed you should. you could try resetting your router. also try holding the power and reset button for 30 seconds after you disconnect the power. Do this 3 times...it should factory default the settings and let you start over. lmk if this helps
