I have 2 gateways on my network, 2wire and cable, each with its own router configured on the same subnet (192.168.1.x) and with only one DHCP enabled. Both routers are connected to each other via a LAN port.
I've had this config for over 5years and it works great, however I'd like to modify to allow inter-operation.
1. I'd like to know how to configure the 2wire router (192.168.1.2) to route LAN request for the cable modem (192.168.100.1) to the cable router (192.168.1.3). This is to allow any pc on the LAN the ability to reset the cable modem.
2. Next if possible I'd like to be able to do the same from 2wire's WAN connection.
