RTX 2060 pc build help
Dropment
852
I need some suggestions with a new build. I was about to buy a pc but i was $40 short so I have to change my build.
*I already have an nzxt h400i and a corsair 650w semi modular psu
For this pc I want to get over 100+ fps in most games on max and do some streaming. My plan before was to get parts that all have the same rgb software but asus has to be expensive for gpus.
My budget is under $1100 and I want to take advantage of the cheap 500gb ssds that are available.
It can be either intel or amd im a fan of both. If it is amd then i would like to have it compatible with the asus aura software
