Question rtx 2060 super fan replacement
Sep 11, 2019
Hi, I want to replace my evga rtx 2060 super fan for a gigabyte gtx 970 fan, do u reckon it’ll fit. If not are there other gigabyte fan and heatsink that will fit on the rtx 2060 super.
LORDPrometheus
552
7
5,365
156
First of all i have no idea why you would want to do this but i can see how you would think this may help. The short answer is don't. GPU heat sinks are specific to the card they are built for and swapping between generations and manufactures is a recipe for breaking something. There are affordable aftermarket fan and heatsink upgrades for most cards i would look at one of those rather than trying to Frankenstein your own
