SubaruWRX244 :
magickman :
SubaruWRX244 :
Make sure the cables are connected to the PSU if you have a modular unit. Use two separate cables to power the GPU instead of a single one. I would unplug the GPU and use two cables and reinsert the GPU and plug back in. Then it should work.
only have 1 cable that branches off to 2 connectors 1- 8 pin and 1- 6 pin, does this mean im gonna need to upgrade my power supply?
Reset and unplug/ plug everything back in and post back with your results. If no luck then I'd suspect the power supply.
Actually before the first post I removed and tried old card and all was good then I put new one in and got same error shutdown removed cables and tried twice more then put old card back in again and thats the one im using as I type this so ill have to check the type of power supply I have and find out what the rtx 2070 needs. Thanks for the help
