[SOLVED] Rtx 2070 OC problem after use MSI AFTERBURNER
Apr 9, 2020
6
Well maybe i make a dumb mistake , i run the OC option in the program, after 20 min show me some OC, after that i test it and shows me no problems.
The thing is make OC to 1890 Mhz, and the defautl value of the card is 1400/ 1650 OC .
welll sound good boost, but generate ramdom frozen screens, so i decide put back the default values, i follow tutorial to press the reset bottom, uninstall the program.
But nothing the OC (1890 Mhz) always stays in heavy loads, no matter what other software to OC i use , keep that value.
Im getting mad , close to format and start from cero win10, but before that i like to ask here if is any another way to get back the defrault value ??
