Question RTX 2070 problems
dalynparkercoffey
Commendable
Jul 14, 2018
27
I have already had my first RTX 2070 fail on me after about a month of use. I RMA'd and got this one. It seems to be doing okay, however it has one problem in particular that the one that failed also had. Both GPUs have been unable to provide me the correct color for some textures in my game. In rust, I run over to junkyard and look around any some of the things that are supposed to be a greenish color arent. Mine appear completely white while my friends are green. This is very weird to me. Also, I noticed in 7 days to die that for some strange reason at like cave entrances and stuff there will be a wall of what looks like glitched textures that I can literally walk through. Would this have something to do with my hardware or is it a problem with the games?
I can provide pictures if needed
D
Deleted member 2731765
Guest
What are your FULL PC specs ? Which PSU model are you using to power up the RTX 2070 (this is very important)? Have you tried doing a CLEAN re-install of the GPU drivers ? What is the GPU and CPU's TEMP value when you play games ?
dalynparkercoffey
Commendable
Jul 14, 2018
27
This is my PC build: https://pcpartpicker.com/list/dqKRZR
PSU Model is EVGA supernova G2 750 watt
I did many driver reinstalls on my previous RTX 2070 and they never seemed to fix the issue.
After running two stress tests, one on my cpu, one on my GPU my temps at full load were:
GPU: 70 celsius I believe the range was something along the lines of 43 celsius Min and 70 celsius max.
CPU: View: https://imgur.com/HijcqBZ
Also under full load.
Sorry for the late reply.
dalynparkercoffey
Commendable
Jul 14, 2018
27
I stress tested the GPU with furmark, and the CPU with Intel(R) Extreme Tuning Utility
