Question RTX 2070 super ( twin fan ) + Ryzen 5 3600 + B450 motherboard
Jul 11, 2019
Hello, community,
I want to build a work station for deep learning.
I am thinking of this combination:
RTX 2070 super (twin fan) + Ryzen 5 3600 + B450 motherboard.
I won't be upgrading for a multi-GPU system in the near future.
My main concerns are of heating and dust issue as I am from a humid and hot region
Also, the price should be less.
Please advise me whether this combination will work fine for me or not?
You'll need a previous gen amd cpu in order to update the b450 board bios to use the 3600 (amd can send you a boot kit if the board of your choice doesnt have usb flashing without cpu). Otherwise you'll need to pickup an x570 board
As long as your case has dust filters and the humidity is non-condensing, it should be fine, but you'd probably want an aftermarket heatsink. Even the old evo212 .
Reactions: How's tom?
That is a good combination. Select a b450 board that has bios flashback and you wont need a 2nd gen Ryzen CPU to update the bios.
Here is a list of boards that have flashback.
ASRock (BIOS Flashback)
None!
ASUS (USB BIOS Flashback)
ASUS Crosshair VI Extreme
ASUS Crosshair VI Hero
ASUS Crosshair VI Hero (Wi-Fi AC)
ASUS Crosshair VII Hero
ASUS Crosshair VII Hero (Wi-Fi)
Gigabyte (Q-Flash Plus)
None!
MSI (Flash BIOS Button) [
View: https://www.youtube.com/watch?v=iTkXunUAriE
MSI B450 Gaming Plus
MSI B450 Gaming Pro Carbon AC
MSI B450 Tomahawk
MSI B450-A Pro
MSI B450M Bazooka Plus
MSI B450M Gaming Plus
MSI B450M Mortar
MSI B450M Mortar Titanium
MSI X370 Gaming M7 ACK
MSI X370 XPower Gaming Titanium
MSI X470 Gaming M7 AC
Thank you for the information. I am building the system with a budget limit and X570 will be little expensive. Can I go with the combination of RTX 2070 super + Ryzen 5 2600/2600X + X470/B450
I will prefer X470 for multi-GPU support option though.
None!
None!
MSI B450 Tomahawk
MSI B450-A Pro
MSI B450M Mortar
Thank you so much for this information. I will definitely prefer to work with a 3600. But little hesitant about the updating the BIOS part as I donot have any experience/knowledge in case some problem appears. Also, exploring other options for buying and maintanance budget issues. What do you think about RTX 2070 super+ Ryzen 5 2600X + X470/B450?
My main aim is to use for conputation work like deep learning.
Latest posts
