[SOLVED] RTX 2080 fans revving high
Oct 9, 2019
Hi
I have an RTX 2080
The fans run-up to what sounds like max when under load.
The temp when it has been under load for a short while sits around 73 - 78 degrees.
without the temp moving the fan will rev upto max, they are very loud.
It isn't constant but it will start up and go loud, then go back to normal.
I tracked the temps and they don't massivly change so why is this happening?
Some forum members seems to find a high GPU temperature quite allright.
I dont.
Because I know from sad experience and basic electronics engineering, that hot electronics have a short life.
Short life could however translate to "few years".
If you plan to upgrade in 2yrs time, its not a big issue then.
If you want to play it safe, do something to keep the temperature at least under the 80°C mark.
This will lessen the risc of getting a thermal shutdown during your favorite game.
I dont.
