Question RTX 2080 idle usage spiking?? PLEASE HELP!
Luke2468
189
Hi there, I just bought an MSI RTX 2080 Gaming Trio X and when it is running at idle it spikes from 0 to around 7 or 9 % usage over and over again. I've opened windows task manager and discovered that "Steam Client WebHelper (32bit)" seems to be what is causing the issue but is this normal? If not is there anything I can do to prevent it or fix it or should I just return the card for another? Thanks!
