RTX 2080 Ti in Cooler Master N600 will it fit?
MLG_No_Scope
Respectable
May 23, 2017
412
55
The case is the following height, width and length: 207mm x 455mm x 520mm.
The GPU is the following height, width and length: 59.944mm x 269.24mm x 114.3mm
Will it fit? yes it will fit.
The case is even so big, almost every GPU will fit (almost)
So conclusion:
Will it Fit?
Answer = YES
MLG_No_Scope
Respectable
May 23, 2017
412
55
So conclusion:
Will it Fit?
Answer = YES
