[SOLVED] rtx 3060 low fps
Feb 6, 2022
8
I recently got my new rtx 3060 but my games are running on low fps and i dont know why
My pc specs:
i5-10600K, asus rog strix b460-f, corsair cx650m 650W,
https://rog.asus.com/motherboards/rog-strix/rog-strix-b460-f-gaming-model/spec
The motherboard supports up to 2933.
Up to 2933 and you are good to go
* 10th Gen Intel® Core™i9/i7 CPUs support 2933/2800/2666/2400/2133
Bunch of boards drop down in the speed using a i5 or 3.
The first search came up with only 2666 with a i5.
https://www.userbenchmark.com/UserRun/50276579
games are - fortnite and fortnite is around 100 to 150 fps and league of legends is 120 to 170 on low/medium
Single channel RAM running at 2133mhz, thats likely hurting your performance. Go into the BIOS and turn on XMP and select 3000mhz. You will still be impacted by single channel (1x16gb vs 2x8gb dual channel) but getting the RAM to 3000mhz should help.
Reactions: FANTAsticmana
When i changed it to 3000mhz my pc didnt even wanted to run. So i guess i have to buy new ram, can u send me tips about which x2 8gb should i get?
Did you enable XMP or just change the frequency to 3000mhz?
Which slot is the RAM installed in?
MB i just change frequency to 3000mhz but now i enable it and when i enable it it automaticlyy move to 2666hz (or 2600hz) and when i change it to 3000 my pc didnt run up
RAM is installed in 4th slot and first slot is blocked by cooler
I will ask again. Which 2x8gb should i get? cause soon i will sell my old graphic card and i want to upgrade my pc by buying 2x8gb because i know its better for computer
The motherboard instructions say you should be using the 2nd (B2) slot when using a single stick. That might help reach 3000mhz.
There is also a support section for tested and approved RAM models. ROG STRIX B460-F GAMING | ROG Strix | Gaming Motherboards|ROG - Republic of Gamers|ROG United Kingdom (asus.com)
Other RAM can work but if you can keep to this list you should minimise the chance of problems.
The problem with second slot is that when i was changing my graphic card my motherboard was showing orange light - DRAM and when i plugged into 4th my pc could easly run up
Not this one though. It has up to 2933 support for all cpus
