Your video card is made for that or the switch would not be their your not actually overclocking the card more or less just using it to the potential of the card.ye the fan start spin on 60c and bios set to normal they say if i switch it off to oc mode it will spin at lower temps the problem is i dont wanna overclock my gpu
Get better case airflow.
brand new pc clean what?I would start by removing it and cleaning it out.
My bad I thought I seen 380.brand new pc clean what?
Full PC specs and load thermals, please.
ye the fan start spin on 60c and bios set to normal they say if i switch it off to oc mode it will spin at lower temps the problem is i dont wanna overclock my gpuMy bad I thought I seen 380.
But a simple google search tells you.
https://www.google.com/search?rlz=1...hUKEwj29NSLsZLuAhVLRK0KHZOAD4sQ4dUDCA0&uact=5
isnt a problem ? my fan constantly going off and on temp bounce 59 60 59 60 on idleThere isn't actually a problem here. Enjoy the card!
That's normal.isnt a problem ? my fan constantly going off and on temp bounce 59 60 59 60 on idle
That's because the temp is sitting right at the border for the default fan profile to engage/disengage.isnt a problem ? my fan constantly going off and on temp bounce 59 60 59 60 on idle
i want to do that but the curve that i did work only if msi after bruner working in the background which is sucks i dont like programs that runing in the background while im playing games its also impact performance there is anyway to apply fan curve to the gpu on msiafterburner that will apply as soon as i bootup to windows without open it?That's because the temp is sitting right at the border for the default fan profile to engage/disengage.
Want to stop that? Then create a custom curve.
Not that I know of.is there anyway to apply fan curve to the gpu on msiafterburner that will apply as soon as i bootup to windows without open it?
there is anyway to disable rivatuner automatic open when i launch afterburner?My 1060 has that fan threshold at 40°C but that is pretty much where it idles so I had the same situation with it constantly turning on and off. I just set a custom fan curve in afterburner and set it to stay off until 45°C and everything is fine. Done that for years on my cards to keep them quiet and cool and never had any issues. Just set it to start with Windows so that it applies the custom fan curve on launch and everything is fine.
Either put the off part higher if you want it to stay passive, or put it lower if you want it to stay a bit cooler, however you like it.
If you want to have the settings to stick with the card, you would need to modify it in the card's BIOS, but since there is no BIOS editor for Pascal cards, you're out of luck with that.
