RTX 3080 , Ryzen 7 5800x , 32 GB RamPlease list your full system specs.
Please post the link to your results instead. Also please list the specs of all the parts in your PC and include each parts exact model.Yeah sure.
https://www.userbenchmark.com/UserRun/50164567Please post the link to your results instead. Also please list the specs of all the parts in your PC and include each parts exact model.
Yeah I don't know why that is with the SSD.Okay so you need to turn off G-sync or freesync if it is on and make sure you do not have any global framerate limiters on. You have high CPU background usage when you did the test. Restart the computer and turn off any non essential programs and services to retest Userbenchmark and post the results link back here. It shows your SSD as being slower than a disk drive which is very concerning. Were you downloading or installing anything when you did the test?
Hellblade is running on DX12DirectX 11 test was not completed ... by any chance Hellblade running on DX 11? That could mean problem with GPU drivers.
BIOS Date | 20201203 |
Version 2423 from 021/08/26
I will look into the BIOS update, and yes both PCIE power cables.Would update the bios,
BIOS Date 20201203
Latest being,
Think btw that Userbenchmark has some issues with the gpu related tests. Can't see why your gpu would be the problem there and had something weird when i tried a test too.
Are you btw using both pcie power cables to power the gpu?
Nah I just let it run lolDo you btw play that stupid game in userbenchmark? Might be necessary to get a good score, don't really have too aim, just keep shooting for a while.
Installed Studio Drivers and played the gameUpdated the post.
I am now seeing some better performance after changing some settings in the control panel and doing what you told me.Seems your problem lies in this one,
https://gpu.userbenchmark.com/Faq/What-is-the-MRender-GPU-benchmark/87#:~:text=Q What is the MRender,target array and geometry shader
cannot figure out why. Looking at others should there be no problem,
https://gpu.userbenchmark.com/Nvidia-RTX-3080/Rating/4080
I did now, there is an improvement, running 70-85 mostly , some lows to 65.Did you already update the bios?
