Build Advice rtx 4090 build for £3000 advice please
Mar 21, 2023
4
Been looking around for a £3000 rtx 4090 build and have come up with the following, have chosen a budget case to attempt to keep the prices down
CORSAIR RM750E 750 WATT POWER SUPPLY £129
IONZ KZ-Z DEEP SPACE TOWER PC CASE £80
MSI VGA RTX 4090 VENTUS £1740
INTEL ICORE I7-13700K £415
CORSAIR ICUE H100I RGB ELITE CPU COOLER £149
SAMSUNG 980 PRO 2TB £180
G.SKILL TRIDENT Z5 RGB 32GB DDR5 £155
GIGABYTE Z790 AORUS ELITE AX INTEL Z790-MOTHERBOARD £305
All these prices are from amazon so maybe I will be able to find them slightly cheaper once i order them but the whole package is around £3000 any suggestions would be appreciated.
Thanks
Thanks
You want a 1000 watt psu and a case with better airflow. Just curious but are you planning on gaming at 4K?
Mar 21, 2023
4
been planning to build a pc for a long time already have a xbox series x and a 4k monitor so thought might as well make proper use of the monitor and if im going to do it i would rather just build a decent rig now that will last a good few years rather than upgrading again next year… but these prices for parts are horrendous i built a few pcs around 15 years ago the whole thing didnt cost as much as a GPU now
Reactions: Why_Me
Give me a few minutes and we can fit you into a 4090 build for £3000 that includes the proper psu and case ^^
https://uk.pcpartpicker.com/product/mpcG3C/fractal-design-pop-air-atx-mid-tower-case-fd-c-por1a-06
Fractal Design Pop Air ATX Mid Tower Case £85.99
https://uk.pcpartpicker.com/product...ly-modular-atx-power-supply-mpg-a1000g-pcie-5
MSI A1000G PCIE-5 1000W 80+ Gold Modular ATX Power Supply £159.00
https://uk.pcpartpicker.com/product...tx-lga1700-motherboard-mag-b760-tomahawk-wifi
MSI MAG B760 TOMAHAWK WIFI £229.97
https://uk.pcpartpicker.com/product...13700f-21-ghz-16-core-processor-bx8071513700f
Intel Core i7-13700F £341.99
https://uk.pcpartpicker.com/product...k-argb-6788-cfm-cpu-cooler-r-ag620-bkanmn-g-2
DeepCool AG620 BK ARGB Dual Tower CPU Cooler £59.98
Low profile RAM so it doesn't impede the cpu cooler.
https://uk.pcpartpicker.com/product...ddr5-6000-cl30-memory-f5-6000j3040f16gx2-rs5k
G.Skill Ripjaws S5 DDR5-6000 32GB (2x16GB) CL30 £153.84
https://uk.pcpartpicker.com/product...tb-m2-2280-nvme-solid-state-drive-wds200t3x0e
Western Digital Black SN770 2TB M.2 PCIe 4.0 x4 NVME SSD £119.99
https://uk.pcpartpicker.com/product...b-video-card-geforce-rtx-4090-gaming-trio-24g
MSI GAMING TRIO GeForce RTX 4090 24GB Video Card £1664.39
https://uk.pcpartpicker.com/product...dows-11-home-retail-download-64-bit-kw9-00664
Microsoft Windows 11 Home Retail - Download 64-bit £109.99
Total: £2925.14 inc VAT
A better look at those components.
https://www.fractal-design.com/products/cases/pop/pop-air/rgb-black-tg-clear/
https://www.msi.com/Motherboard/MAG-B760-TOMAHAWK-WIFI
https://www.deepcool.com/products/C...K-ARGB-Dual-Tower-CPU-Cooler/2022/16082.shtml
https://www.intel.com/content/www/u...-30m-cache-up-to-5-20-ghz/specifications.html
https://www.msi.com/Graphics-Card/GeForce-RTX-4090-GAMING-TRIO-24G
AM5 Ryzen option, so you can upgrade your cpu later if u wish to do so:
The 7800X3D is launching on 6th April
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor (£226.97 @ Laptops Direct)
CPU Cooler: Deepcool AG500 BK ARGB 67.88 CFM CPU Cooler (£40.00 @ Computer Orbit)
Motherboard: ASRock B650E PG RIPTIDE WIFI ATX AM5 Motherboard (£262.62 @ Amazon UK)
Memory: Corsair Vengeance RGB 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory (£125.99 @ Amazon UK)
Storage: Sabrent Rocket Q4 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£126.99 @ Amazon UK)
Video Card: Inno3D iChill X3 GeForce RTX 4090 24 GB Video Card (£1710.22 @ NeoComputers)
Case: Fractal Design Pop Air ATX Mid Tower Case (£83.54 @ Box Limited)
Power Supply: NZXT C1000 (2022) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply (£145.99 @ MoreCoCo)
Total: £2722.32
Generated by PCPartPicker 2023-03-22 10:54 GMT+0000
LORYT699
176
thank you for this im going to have a look through this seems like a £300 saving
yes but you can t oc your cpu(and is clocked a little bit lower) and you don t have the igpu, if is ok for you it will be the best option.
Also the one you have done is an actual good high end rig, just curious for which speed and timeing were the trident z5 you have found.
I suggest to avoid the ventus and the low low end custom gpu cause they are actually bad, so the best thing I think is change from your build the ventus with another and your choice to choose between the i7 k model or non k depending how much you are budget limited, and if you choose a non k then a a b760 could be the best option for you.
Also I ve to remember you that non k cpu have a way lower tdp(65W) so a 850 psu will be ok.
1 last thing, if you are planning just gaming at 4k and you want to get as much as possible low budget I can suggest the 13600k and not the i7 cause in 4k and 2k they are almost the same with an high price gap.
The biggest suggestion I can give then is watch as many bench on yt befor you buy so you will have a cleaner idea on what you want and actually need
