Question RTX 4090 fan speeds are at 1450 RPM while idle ?
Nov 23, 2024
4
Hello I got a new Dell Alienware AW3225QF monitor and it's making my RTX 4090 fans constantly spin at 1450rpm while idle. Is this because of the 240hz refresh rate? I do have two 4k monitors hooked up to it. With my previous setup I had one 4k monitor and one 1080p monitor hooked up to the GPU and the gpu fans would be off while idling. Any suggestions or help would be appreciated! Also, I did check NVIDIA control panel to make sure my power settings were set to normal. Thank you in advance!
Reactions: IceDeer12
The fans of the nvidia series 40 usually stop completely when idle. Your problem cannot be answered until you send a screenshot from something like GPU-Z, HWINfo or MSI Afterburner where the frequency, load, temperature, etc. would be shown.
