Running 1 4k monitor and 2 1080p monitors doable?
Matthew Mayberry
4
Simple as title. I would like to run a 4k monitor as my main monitor in the middle, with my 2 current monitors on each side (running 1080p)
My setup would be SLI GTX 970s (Gigabyte G1)
Is this as simple as setting it up and configuring it like you do normal multiple monitor setups, is it even possible?
Its possible you just need to configure it through windows or the nvidia control panel. For windows config, right click on your desktop and click resolution and configure.
gilbadon
You may want to contact the manufacturer on this one friend... They will get back to you in a day most times with a better answer than we have. I barely understand my G1 and I use 3 monitors. I know it is capable of 4 separate monitors, so the driving power is probably not an issue.
Matthew Mayberry
4
That's what I had thought that it would be, but it's always safe to check before I just assume and spend the money for 4k.
